Einleitung
This guide explains how to replace the joysticks in the Yuneec ST16S. The joysticks allow you to control the drone while it is in flight. You can find out if your joysticks need to be replaced by checking out the Yuneec ST16S Troubleshooting.
Was du brauchst
Hold down the button located above the battery while applying downward pressure to the battery.
Fast fertig!
Abschluss
