Einleitung
This guide explains how to replace the speakers in the Yuneec ST16S. You can find out if the speakers need to be replaced by checking out the Yuneec ST16S Troubleshooting.
Was du brauchst
Hold down the button located above the battery while applying downward pressure to the battery.
Remove the four screws from around the speaker and remove the plastic cover.
Fast fertig!
Abschluss
