Zum Hauptinhalt wechseln
ZTE Blade X Max Battery Replacement
Was du brauchst
  1. ZTE Blade X Max Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 ZTE Blade X Max Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Use the iOpener or heating pad to heat around the edges of the phone to melt the adhesive.
    • It will take about ten minutes for the adhesive to be heated enough to remove the backing.
    • You will have to reheat the iOpener or heating pad a few times.
  2. ZTE Blade X Max Battery Replacement: Schritt 2, Bild 1 von 3 ZTE Blade X Max Battery Replacement: Schritt 2, Bild 2 von 3 ZTE Blade X Max Battery Replacement: Schritt 2, Bild 3 von 3
    • Slide the Jimmy along the under backing and lightly push the plastic up.
    • You will hear a snapping sound as you slide the Jimmy along the backing. This is from the closures releasing. There should be seven total closures on either side of the device, and three on the top and bottom.
  3. ZTE Blade X Max Battery Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the backing from the phone once the closures are released.
    • If you do not open all of the closures on the backing do not attempt to pry it off.
    • Be careful when opening the back of the phone. The fingerprint scanner is connected by a thin film that will tear if pulled too roughly.
  4. ZTE Blade X Max Battery Replacement: Schritt 4, Bild 1 von 3 ZTE Blade X Max Battery Replacement: Schritt 4, Bild 2 von 3 ZTE Blade X Max Battery Replacement: Schritt 4, Bild 3 von 3
    • Remove the opaque yellow sticker that indicates where the fingerprint scanner is connected to the back of the device.
  5. ZTE Blade X Max Battery Replacement: Schritt 5, Bild 1 von 3 ZTE Blade X Max Battery Replacement: Schritt 5, Bild 2 von 3 ZTE Blade X Max Battery Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove the two 1mm Phillips #000 screws on the small panel that was underneath the sticker.
    • Use the tweezers to remove the panel.
  6. ZTE Blade X Max Battery Replacement: Schritt 6, Bild 1 von 2 ZTE Blade X Max Battery Replacement: Schritt 6, Bild 2 von 2
    • Use the tweezers to pull at the base of the film to remove the fingerprint scanner.
  7. ZTE Blade X Max Battery Replacement, Midframe: Schritt 7, Bild 1 von 1
    • Remove the SD and SIM cards by pulling out the card tray from the slot on the right side of the device.
  8. ZTE Blade X Max Battery Replacement: Schritt 8, Bild 1 von 3 ZTE Blade X Max Battery Replacement: Schritt 8, Bild 2 von 3 ZTE Blade X Max Battery Replacement: Schritt 8, Bild 3 von 3
    • Remove the sixteen 1mm Phillips #000 screws from the midframe of the phone.
  9. ZTE Blade X Max Battery Replacement: Schritt 9, Bild 1 von 3 ZTE Blade X Max Battery Replacement: Schritt 9, Bild 2 von 3 ZTE Blade X Max Battery Replacement: Schritt 9, Bild 3 von 3
    • Use the Jimmy to remove the midframe from the device.
  10. ZTE Blade X Max Battery Replacement, Battery: Schritt 10, Bild 1 von 1
    • Use the iOpener or heating pad to heat the phone. This will loosen the adhesive below the battery.
    • Do not apply the iOpener directly to the battery. Place the iOpener on the opposite side of the phone to indirectly melt the battery's adhesive.
  11. ZTE Blade X Max Battery Replacement: Schritt 11, Bild 1 von 3 ZTE Blade X Max Battery Replacement: Schritt 11, Bild 2 von 3 ZTE Blade X Max Battery Replacement: Schritt 11, Bild 3 von 3
    • Use the spudger to pry the battery out of its slot after it has been thoroughly heated.
    • If the adhesive is still strong, reheat the opposite side of the phone until you can easily remove the battery.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 1,185
