Zum Hauptinhalt wechseln
ZTE Lever Loud Speaker Replacement
Was du brauchst
  1. ZTE Lever Loud Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. ZTE Lever Loud Speaker Replacement: Schritt 2, Bild 1 von 2 ZTE Lever Loud Speaker Replacement: Schritt 2, Bild 2 von 2
    • Use an iFixit opening tool to separate the back from the device.
  3. ZTE Lever Loud Speaker Replacement: Schritt 3, Bild 1 von 2 ZTE Lever Loud Speaker Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. ZTE Lever Loud Speaker Replacement: Schritt 4, Bild 1 von 2 ZTE Lever Loud Speaker Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. ZTE Lever Loud Speaker Replacement: Schritt 5, Bild 1 von 1
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
  6. ZTE Lever Loud Speaker Replacement, Volume Buttons: Schritt 6, Bild 1 von 1
    • Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
  7. ZTE Lever Loud Speaker Replacement: Schritt 7, Bild 1 von 3 ZTE Lever Loud Speaker Replacement: Schritt 7, Bild 2 von 3 ZTE Lever Loud Speaker Replacement: Schritt 7, Bild 3 von 3
    • Remove the top plastic motherboard cover using a plastic opening tool.
  8. ZTE Lever Loud Speaker Replacement: Schritt 8, Bild 1 von 2 ZTE Lever Loud Speaker Replacement: Schritt 8, Bild 2 von 2
    • Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
  9. ZTE Lever Loud Speaker Replacement: Schritt 9, Bild 1 von 2 ZTE Lever Loud Speaker Replacement: Schritt 9, Bild 2 von 2
    • Peel up the volume button cable from the phone with hands, or plastic opening tool.
  10. ZTE Lever Loud Speaker Replacement, Power Button: Schritt 10, Bild 1 von 1
    • Disconnect the power button from the motherboard with a plastic opening tool.
  11. ZTE Lever Loud Speaker Replacement: Schritt 11, Bild 1 von 2 ZTE Lever Loud Speaker Replacement: Schritt 11, Bild 2 von 2
    • Peel the power button cable up from the phone with you hands, or a plastic opening tool.
  12. ZTE Lever Loud Speaker Replacement, Motherboard: Schritt 12, Bild 1 von 2 ZTE Lever Loud Speaker Replacement, Motherboard: Schritt 12, Bild 2 von 2
    • Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
  13. ZTE Lever Loud Speaker Replacement: Schritt 13, Bild 1 von 1
    • Remove the bottom plastic motherboard cover with your fingers
  14. ZTE Lever Loud Speaker Replacement: Schritt 14, Bild 1 von 2 ZTE Lever Loud Speaker Replacement: Schritt 14, Bild 2 von 2
    • Disconnect the camera from the motherboard with a plastic opening tool.
  15. ZTE Lever Loud Speaker Replacement: Schritt 15, Bild 1 von 1
    • Disconnect the display cable from the motherboard with a plastic opening tool.
  16. ZTE Lever Loud Speaker Replacement: Schritt 16, Bild 1 von 3 ZTE Lever Loud Speaker Replacement: Schritt 16, Bild 2 von 3 ZTE Lever Loud Speaker Replacement: Schritt 16, Bild 3 von 3
  17. ZTE Lever Loud Speaker Replacement: Schritt 17, Bild 1 von 1
    • Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
  18. ZTE Lever Loud Speaker Replacement: Schritt 18, Bild 1 von 1
    • Pry the motherboard cell battery from its position on the case of the phone
  19. ZTE Lever Loud Speaker Replacement: Schritt 19, Bild 1 von 3 ZTE Lever Loud Speaker Replacement: Schritt 19, Bild 2 von 3 ZTE Lever Loud Speaker Replacement: Schritt 19, Bild 3 von 3
    • Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
  20. ZTE Lever Loud Speaker Replacement: Schritt 20, Bild 1 von 1
    • Remove the motherboard with your fingers.
  21. ZTE Lever Loud Speaker Replacement, Loud Speaker: Schritt 21, Bild 1 von 2 ZTE Lever Loud Speaker Replacement, Loud Speaker: Schritt 21, Bild 2 von 2
    • Using the plastic opening tool, remove the speaker.
Abschluss
Luke Kilbourne
294 Reputation
2 Anleitungen geschrieben
USF Tampa, Team S5-G2, Passmore Spring 2018 Mitglied von USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 182
