Was du brauchst
Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
Remove the cover.
Remove the three 1.6mm Phillips #0 screws from the plastic cover on the motherboard.
Use a plastic opening tool to flip up the retaining flap on the volume ribbon cable ZIF socket.
Peel up the volume button cable from the phone with hands, or plastic opening tool.
Disconnect the power button from the motherboard with a plastic opening tool.
Peel the power button cable up from the phone with you hands, or a plastic opening tool.
Remove the seven 1.6mm Phillips #0 screws from the plastic cover on the bottom of the motherboard.
Disconnect the display cable from the motherboard with a plastic opening tool.
Disconnect the rear speaker cable from the motherboard with a plastic opening tool.
Using the plastic opening tool, pry the motherboard up, sliding along the edge to separate the pieces.
Slide the 2 ribbon cables through their respective holes before separating the case from the screen.
Gently lift up the case from the screen.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
