Zum Hauptinhalt wechseln
ZTE Maven 2 Motherboard Replacement
Was du brauchst
  1. ZTE Maven 2 Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 3 ZTE Maven 2 Motherboard Replacement, Back Cover: Schritt 1, Bild 2 von 3 ZTE Maven 2 Motherboard Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Pry off the back cover by inserting an opening tool into the small space on the bottom left between the phone's cover and body.
    • Work your way around the phone with an opening pick to loosen the rest of the back cover.
    • Remove the cover.
  2. ZTE Maven 2 Motherboard Replacement, Battery: Schritt 2, Bild 1 von 1
    • Push in and then up on the bottom of the battery to free it from its compartment.
    • Pull the battery out.
  3. ZTE Maven 2 Motherboard Replacement, MicroSD Card: Schritt 3, Bild 1 von 2 ZTE Maven 2 Motherboard Replacement, MicroSD Card: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using your fingers or blunt tweezers, carefully pull the memory card out of the slot.
    • A SIM card is used to demonstrate the process for removing the MicroSD card in these images.
  4. ZTE Maven 2 Motherboard Replacement, Midframe: Schritt 4, Bild 1 von 1
    • Remove the twelve 3 mm screws with a Phillips #00 screwdriver.
  5. ZTE Maven 2 Motherboard Replacement: Schritt 5, Bild 1 von 3 ZTE Maven 2 Motherboard Replacement: Schritt 5, Bild 2 von 3 ZTE Maven 2 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Wedge the opening tool between the front and side panel to create a gap.
    • Slide the opening pick around the device to detach the midframe.
  6. ZTE Maven 2 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 3 ZTE Maven 2 Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 3 ZTE Maven 2 Motherboard Replacement, Motherboard: Schritt 6, Bild 3 von 3
    Kaufen
    • Peel the sticker off the battery compartment, as some of the motherboard components are hidden under it.
    • Remove the six 3 mm screws with a Phillips #00 screwdriver.
    • Using a pair of blunt tweezers, carefully remove the black wire that's attached to the gold plates on the left side of the device.
  7. ZTE Maven 2 Motherboard Replacement: Schritt 7, Bild 1 von 2 ZTE Maven 2 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Using the opening tool, carefully detach the ribbon cables connected to the motherboard.
  8. ZTE Maven 2 Motherboard Replacement: Schritt 8, Bild 1 von 2 ZTE Maven 2 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Work the opening pick around the edges of the motherboard to loosen it up.
    • The motherboard is glued down with adhesive. Pushing firmly with the pick will help to loosen the components and remove them.
    • Pull the motherboard out of the device.
Abschluss
Kristen Gismondi
82.716 Reputation
202 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 56
