Einleitung
This guide will help you replace the battery of your ZTE Prestige 2. Before you start, check out our troubleshooting page that will help you decipher any basic problems before taking your device apart. Some reasons you may need to conduct this replacement is because the battery may be burnt out, or have water damage. Before beginning, make sure to power off your device completely and disconnect from any external power source.
Was du brauchst
Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
