Zum Hauptinhalt wechseln
ZTE Prestige 2 Motherboard Replacement
Was du brauchst
  1. ZTE Prestige 2 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 ZTE Prestige 2 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 ZTE Prestige 2 Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Motherboard Replacement: Schritt 2, Bild 1 von 2 ZTE Prestige 2 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery.
  3. ZTE Prestige 2 Motherboard Replacement, Back Panel: Schritt 3, Bild 1 von 3 ZTE Prestige 2 Motherboard Replacement, Back Panel: Schritt 3, Bild 2 von 3 ZTE Prestige 2 Motherboard Replacement, Back Panel: Schritt 3, Bild 3 von 3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Motherboard Replacement: Schritt 4, Bild 1 von 3 ZTE Prestige 2 Motherboard Replacement: Schritt 4, Bild 2 von 3 ZTE Prestige 2 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
  5. ZTE Prestige 2 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Remove the three 3 mm Phillips #00 screws on the edges of the motherboard.
  6. ZTE Prestige 2 Motherboard Replacement: Schritt 6, Bild 1 von 3 ZTE Prestige 2 Motherboard Replacement: Schritt 6, Bild 2 von 3 ZTE Prestige 2 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Use the iFixit opening tool to dig under the sticker where the volume and the power buttons are located on both sides.
  7. ZTE Prestige 2 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Use the curved tweezers to gently remove the black cable running down the left side of the device and disconnect it from its socket.
  8. ZTE Prestige 2 Motherboard Replacement: Schritt 8, Bild 1 von 3 ZTE Prestige 2 Motherboard Replacement: Schritt 8, Bild 2 von 3 ZTE Prestige 2 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Use the curved tweezers to then unlock each of the ZIF connectors and pull the cables out.
    • The motherboard should now be able to fully disconnect from the rest of the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Maria Stock
524 Reputation
5 Anleitungen geschrieben
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Mitglied von UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 198
