Zum Hauptinhalt wechseln
ZTE Prestige 2 Power and Volume Buttons Replacement
Was du brauchst
  1. ZTE Prestige 2 Power and Volume Buttons Replacement, Battery: Schritt 1, Bild 1 von 3 ZTE Prestige 2 Power and Volume Buttons Replacement, Battery: Schritt 1, Bild 2 von 3 ZTE Prestige 2 Power and Volume Buttons Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use the iFixit opening tool to open up the device by wedging the tool under the back case and popping it open.
  2. ZTE Prestige 2 Power and Volume Buttons Replacement: Schritt 2, Bild 1 von 2 ZTE Prestige 2 Power and Volume Buttons Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery.
  3. ZTE Prestige 2 Power and Volume Buttons Replacement, Back Panel: Schritt 3, Bild 1 von 3 ZTE Prestige 2 Power and Volume Buttons Replacement, Back Panel: Schritt 3, Bild 2 von 3 ZTE Prestige 2 Power and Volume Buttons Replacement, Back Panel: Schritt 3, Bild 3 von 3
    • Use a Phillips #00 screwdriver to unscrew all 12 of the 3 mm Phillips screws located along the edges of the device’s back panel, as well as the blue 3mm Phillips screw labeled “ZTE” located towards the top right.
  4. ZTE Prestige 2 Power and Volume Buttons Replacement: Schritt 4, Bild 1 von 3 ZTE Prestige 2 Power and Volume Buttons Replacement: Schritt 4, Bild 2 von 3 ZTE Prestige 2 Power and Volume Buttons Replacement: Schritt 4, Bild 3 von 3
    • Then use the iFixit opening tool and wedge it under the grey back panel and pop it off.
    • There will be a lot of resistance, apply adequate pressure.
  5. ZTE Prestige 2 Power and Volume Buttons Replacement, Power and Volume Buttons: Schritt 5, Bild 1 von 2 ZTE Prestige 2 Power and Volume Buttons Replacement, Power and Volume Buttons: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Use the curved tweezers to pull upwards and out on the the thin plastic attached on both sides of the power button and volume buttons. This process should allow the buttons to pop right out.
Abschluss
UW Stout, Team S1-G4, Schneider-Bateman Spring 2020 Mitglied von UW Stout, Team S1-G4, Schneider-Bateman Spring 2020
UWSTOUT-SCHNEIDER-BATEMAN-S20S1G4
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 130
