Zum Hauptinhalt wechseln
Zebra ZP 450 Power Switch Replacement
Was du brauchst
  1. Zebra ZP 450 Power Switch Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Remove the three 12mm screws from the bottom of the printer using a Phillips #1 screwdriver.
    • Using the TR10 Torx screwdriver, remove the four 8mm screws from the bottom of the device.
  2. Zebra ZP 450 Power Switch Replacement: Schritt 2, Bild 1 von 1
    • Remove the single 7mm screw located underneath the outfeed using the same Phillips #1 screwdriver.
  3. Zebra ZP 450 Power Switch Replacement: Schritt 3, Bild 1 von 1
    • Using an opening pick, pry the plastic covering from around the power button and accessory ports.
  4. Zebra ZP 450 Power Switch Replacement: Schritt 4, Bild 1 von 3 Zebra ZP 450 Power Switch Replacement: Schritt 4, Bild 2 von 3 Zebra ZP 450 Power Switch Replacement: Schritt 4, Bild 3 von 3
    • After lifting the plastic casing from the device, use the Phillips #1 screwdriver to remove the single 5mm screw securing the motherboard.
    • Remove all connections to the motherboard.
  5. Zebra ZP 450 Power Switch Replacement, Power Switch: Schritt 5, Bild 1 von 1
    • Using the soldering iron, unsolder the joints on the back of the motherboard connecting the power switch to the motherboard.
    • For more information on proper soldering technique, please visit the How to Solder and Desolder Connections guide.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 181
