Einleitung
This guide will help you to disassemble your tablet and replace your battery. This procedure should take no more then forty minutes to complete. The process will include using a soldering tool and sharp objects.
Was du brauchst
Remove the back casing by slowly popping each tab out with a plastic opening tool.
Remove the black clips from both sides of the casing with a plastic opening tool.
To remove the battery use an iFixit opening tool to pry the battery apart from the sticky glue.
To completely disconnect the battery, locate the two metal tabs connected to the small circuit board.
Using a soldering tool, you will desolder the tabs from the circuit board.
To insert the new battery, you will need to solder the two new metal tabs back onto the small circuit board.
Please refer to Wie man Lötverbindungen herstellt und entlötet
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
3 Kommentare
will this be the same for a tbqc 1065b?
how do i replace the screen mine has cracks?
This was my daughter's ...but the yeIIow pack the battery in is BLOWN TIGHT BULGING LIKE A BALLOON. DO I dare try to pry it off...not sure if it will exoIode. Yikes!!! She was murdered so I want to save it
