Einleitung
This guide can be used to take out a Zenbre SoundBank Z3 speaker grill in order to replace it with a new one. The Essential Electronics toolkit, iFixit Opening Tool, and 64-Bit Driver Kit will be used.
Was du brauchst
Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
Remove the plastic panel.
Remove the three silver Phillips screws from the plastic ring that holds the speaker in place.
These are the joints that need to be soldered. Follow this guide link to help you remove the wires from the motherboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
