Zum Hauptinhalt wechseln
Zenbre SoundBank Z3 Speaker Replacement
Was du brauchst
  1. Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: Schritt 1, Bild 1 von 2 Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: Schritt 1, Bild 2 von 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Replacement: Schritt 3, Bild 1 von 2 Zenbre SoundBank Z3 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: Schritt 4, Bild 1 von 3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: Schritt 4, Bild 2 von 3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: Schritt 4, Bild 3 von 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Replacement, Speakers: Schritt 5, Bild 1 von 2 Zenbre SoundBank Z3 Speaker Replacement, Speakers: Schritt 5, Bild 2 von 2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  6. Zenbre SoundBank Z3 Speaker Replacement: Schritt 6, Bild 1 von 2 Zenbre SoundBank Z3 Speaker Replacement: Schritt 6, Bild 2 von 2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  7. Zenbre SoundBank Z3 Speaker Replacement: Schritt 7, Bild 1 von 2 Zenbre SoundBank Z3 Speaker Replacement: Schritt 7, Bild 2 von 2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cherian Thomas
334 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 3-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G2
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 475
