Einleitung
Before removing and replacing the sensor of Zoomer Dino Boomer, check the Troubleshooting Page to make sure the issue with gesture mode cannot be fixed without removing the sensor.
Was du brauchst
Unscrew the two 7.5 mm Phillips #0 screws at the base of the neck.
Remove the two 7.2 mm Phillips #0 screws above these at the base of the mouth.
Remove the roof of Zoomer Dino Boomer's mouth by unscrewing the 7.5 mm Phillips #0 screw.
Use a soldering iron to remove the wires from the sensor chip by melting the metal joints on the chip.
Use the tweezers to remove the wires as you are soldering them.
