Zum Hauptinhalt wechseln
Zoomer Dino Boomer Nose Sensor Replacement
Was du brauchst
  1. Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: Schritt 1, Bild 1 von 2 Zoomer Dino Boomer Nose Sensor Replacement, Nose Sensor: Schritt 1, Bild 2 von 2
    • Unscrew the two 7.5 mm Phillips #0 screws at the base of the neck.
    • Remove the two 7.2 mm Phillips #0 screws above these at the base of the mouth.
  2. Zoomer Dino Boomer Nose Sensor Replacement: Schritt 2, Bild 1 von 2 Zoomer Dino Boomer Nose Sensor Replacement: Schritt 2, Bild 2 von 2
    • Use the spudger to pry Zoomer Dino Boomer's lower jaw from its mouth.
  3. Zoomer Dino Boomer Nose Sensor Replacement: Schritt 3, Bild 1 von 2 Zoomer Dino Boomer Nose Sensor Replacement: Schritt 3, Bild 2 von 2
    • Remove the roof of Zoomer Dino Boomer's mouth by unscrewing the 7.5 mm Phillips #0 screw.
  4. Zoomer Dino Boomer Nose Sensor Replacement: Schritt 4, Bild 1 von 2 Zoomer Dino Boomer Nose Sensor Replacement: Schritt 4, Bild 2 von 2
    • Carefully push the sensors out of the nose socket with your fingers.
  5. Zoomer Dino Boomer Nose Sensor Replacement: Schritt 5, Bild 1 von 3 Zoomer Dino Boomer Nose Sensor Replacement: Schritt 5, Bild 2 von 3 Zoomer Dino Boomer Nose Sensor Replacement: Schritt 5, Bild 3 von 3
    • Use a soldering iron to remove the wires from the sensor chip by melting the metal joints on the chip.
    • Use the tweezers to remove the wires as you are soldering them.
    • Do not touch any parts of Zoomer Dino Boomer or yourself when using the soldering iron. The soldering iron will be very hot.
    • When reassembling, extra solder may be required to reconnect the wires with the circuit board.
  6. Zoomer Dino Boomer Nose Sensor Replacement: Schritt 6, Bild 1 von 1
    • Remove and replace the nose sensor.
Abschluss
Lauren Mannix
392 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 16-1, Wollert Fall 2015 Mitglied von USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 7
Insgesamt: 1,242
