Zum Hauptinhalt wechseln
Zoomer Jurassic World Indominus Rex Eye LED Replacement
Was du brauchst
  1. Zoomer Jurassic World Indominus Rex Eye LED Replacement, Mouth Part: Schritt 1, Bild 1 von 2 Zoomer Jurassic World Indominus Rex Eye LED Replacement, Mouth Part: Schritt 1, Bild 2 von 2
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Eye LED Replacement: Schritt 2, Bild 1 von 3 Zoomer Jurassic World Indominus Rex Eye LED Replacement: Schritt 2, Bild 2 von 3 Zoomer Jurassic World Indominus Rex Eye LED Replacement: Schritt 2, Bild 3 von 3
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Eye LED Replacement, Eye LED: Schritt 3, Bild 1 von 2 Zoomer Jurassic World Indominus Rex Eye LED Replacement, Eye LED: Schritt 3, Bild 2 von 2
    • Remove the four (4) 7.5mm Phillips screws from the pieces holding the circuit board for the LEDs in place.
    • Use tweezers to pull the circuit board out of place.
    • Pull directly upward! Be careful not to break the circuit board during removal.
  4. Zoomer Jurassic World Indominus Rex Eye LED Replacement: Schritt 4, Bild 1 von 1
    • Use a soldering iron to disconnect the four (4) wires from the circuit board.
    • Soldering technique guide from iFixit can be found here.
    • Be careful not to burn yourself or the plastic while soldering!
Abschluss
Luke Selby
624 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 10-3, Remmell Spring 2016 Mitglied von USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 332
