Zum Hauptinhalt wechseln
Zoomer Jurassic World Indominus Rex Motherboard Replacement
Was du brauchst
  1. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Turn off and unplug Zoomer Jurassic World Indominus Rex from any power source before doing replacements.
    • Remove all eight (8) 9.3mm Phillips screws using Phillips #1 screwdriver.
  2. Zoomer Jurassic World Indominus Rex Motherboard Replacement: Schritt 2, Bild 1 von 2 Zoomer Jurassic World Indominus Rex Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Pry apart the back cover of the Jurassic Indominus Rex and the rest of the body using a spudger.
    • Do not take out the back cover immediately as it it still attached to the motherboard by a wire.
  3. Zoomer Jurassic World Indominus Rex Motherboard Replacement: Schritt 3, Bild 1 von 2 Zoomer Jurassic World Indominus Rex Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the orange wire that connects the motherboard and the back cover.
    • Separate the back cover and the rest of the Zoomer Jurassic World Indominus Rex.
    • Gently press the tab on the side of the orange connector if you are having trouble disconnecting the wire.
  4. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 2 Zoomer Jurassic World Indominus Rex Motherboard Replacement, Motherboard: Schritt 4, Bild 2 von 2
    • Let the toy rest firmly on a flat surface before processing to the next step.
    • Gently pull each wire out of the connector on the motherboard. Use a set of tweezers, if necessary.
  5. Zoomer Jurassic World Indominus Rex Motherboard Replacement: Schritt 5, Bild 1 von 2 Zoomer Jurassic World Indominus Rex Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Remove the two (2) #0 7.5mm phillips screws from the left side of the motherboard.
    • Remove the one (1) 7.5mm #0 phillips screw from the right side of the motherboard.
  6. Zoomer Jurassic World Indominus Rex Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Use a soldering iron to remove the red and black wires from the motherboard .
    • Soldering technique guide from iFixit can be found here.
    • Use caution while soldering to avoid being burned.
Abschluss
Anh Le
504 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 10-3, Remmell Spring 2016 Mitglied von USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 737
