Zum Hauptinhalt wechseln
iHip Fold-up Portable Speaker Replacement
Was du brauchst
  1. iHip Fold-up Portable Speaker Replacement, Removing the battery case cover: Schritt 1, Bild 1 von 1
    • Use your fingers to slide the battery case cover off in the direction of the arrows.
  2. iHip Fold-up Portable Speaker Replacement, Cleaning the battery case: Schritt 2, Bild 1 von 3 iHip Fold-up Portable Speaker Replacement, Cleaning the battery case: Schritt 2, Bild 2 von 3 iHip Fold-up Portable Speaker Replacement, Cleaning the battery case: Schritt 2, Bild 3 von 3
    • Remove the four AAA batteries. Be sure to check your nearest battery recycling point!
    • Use the detailing brush and a paper towel to remove any corrosion left by previous batteries.
  3. iHip Fold-up Portable Speaker Replacement, Removing the screws: Schritt 3, Bild 1 von 2 iHip Fold-up Portable Speaker Replacement, Removing the screws: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Unscrew the four outer 1.0 mm screws with a Phillips-Head screwdriver.
    • Screws will be magnetized in position and will require the use of tweezers to be removed.
    • Push down gently on the battery case cover and slide it in the direction the arrows indicate. Remove the batteries.
    • Unscrew the 0.6 mm screw located in the center of the battery case.
    • Keep the 1.0 mm and 0.6 mm screws separate from each other for reassembly.
  4. iHip Fold-up Portable Speaker Replacement, Removing the back cover: Schritt 4, Bild 1 von 2 iHip Fold-up Portable Speaker Replacement, Removing the back cover: Schritt 4, Bild 2 von 2
    • Remove the back cover carefully; there are many wires that connect it to the device.
  5. iHip Fold-up Portable Speaker Replacement, Locating Speakers: Schritt 5, Bild 1 von 1
    • Locate the two individual speakers on either side of the front cover.
  6. iHip Fold-up Portable Speaker Replacement, Removing Individual Speakers: Schritt 6, Bild 1 von 3 iHip Fold-up Portable Speaker Replacement, Removing Individual Speakers: Schritt 6, Bild 2 von 3 iHip Fold-up Portable Speaker Replacement, Removing Individual Speakers: Schritt 6, Bild 3 von 3
    • Use a plastic opening tool to scrape off the glue around the speakers.
    • Gently pull the speaker up to detach it from the front cover.
    • Desolder the black and red wires from the speaker unit.
    • Use a hot glue gun to secure the new speaker. Solder the black and red speaker wires back in place.
Abschluss
Lisa
207 Reputation
2 Anleitungen geschrieben
Clemson, Team 3-4, Benson Fall 2014 Mitglied von Clemson, Team 3-4, Benson Fall 2014
CLEM-BENSON-F14S3G4
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 727
