Zum Hauptinhalt wechseln
iHome IH11 Control Buttons Replacement
Was du brauchst
  1. iHome IH11 Control Buttons Replacement, Outer Case: Schritt 1, Bild 1 von 1
    • Unscrew the two 9.0 mm screws with the Phillips #1 screwdriver.
    • Remove the translucent bottom case.
  2. iHome IH11 Control Buttons Replacement: Schritt 2, Bild 1 von 2 iHome IH11 Control Buttons Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
    • Repeat the previous step for the two screws on the bottom.
  3. iHome IH11 Control Buttons Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 9mm screws from the top of the iHome with a Phillips #1 Screwdriver.
  4. iHome IH11 Control Buttons Replacement: Schritt 4, Bild 1 von 1
    • Pop the dock connector out of the iHome and gently pull the white plastic plug from the dock connector.
  5. iHome IH11 Control Buttons Replacement: Schritt 5, Bild 1 von 1
    • Carefully pull apart the device.
    • Remove the four screws that hold the circuit board for the buttons.
  6. iHome IH11 Control Buttons Replacement: Schritt 6, Bild 1 von 1
    • Desolder the four connections for the broken button.
    • Solder the new button in the place of the old one.
    • For more information about soldering, refer to the soldering device page. Soldering Skills
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team 14-9, Maness Spring 2013 Mitglied von Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 11
Letzte 30 Tage: 72
Insgesamt: 571
