Zum Hauptinhalt wechseln
iLive IKBC384S FM/AM Antenna Replacement
Was du brauchst
  1. iLive IKBC384S  FM/AM Antenna Replacement, Top Cover: Schritt 1, Bild 1 von 2 iLive IKBC384S  FM/AM Antenna Replacement, Top Cover: Schritt 1, Bild 2 von 2
    • Make sure you remove all seven 3 mm screws before proceeding to the next step.
  2. iLive IKBC384S  FM/AM Antenna Replacement: Schritt 2, Bild 1 von 2 iLive IKBC384S  FM/AM Antenna Replacement: Schritt 2, Bild 2 von 2
    • Use iOpener or heat gun on all sides except the front.
  3. iLive IKBC384S  FM/AM Antenna Replacement: Schritt 3, Bild 1 von 2 iLive IKBC384S  FM/AM Antenna Replacement: Schritt 3, Bild 2 von 2
    • Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
    • The top of the device will be very difficult to remove because of the adhesive holding it together.
  4. iLive IKBC384S  FM/AM Antenna Replacement, FM/AM Antenna: Schritt 4, Bild 1 von 2 iLive IKBC384S  FM/AM Antenna Replacement, FM/AM Antenna: Schritt 4, Bild 2 von 2
    • Remove all four screws(13.5 mm in length) that are securing the disk drive.
  5. iLive IKBC384S  FM/AM Antenna Replacement: Schritt 5, Bild 1 von 2 iLive IKBC384S  FM/AM Antenna Replacement: Schritt 5, Bild 2 von 2
    • Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
    • Also, disconnect the two power connectors from the motherboard.
    • Once you have removed the ribbon cables and two connectors on the motherboard the disk drive can be removed.
  6. iLive IKBC384S  FM/AM Antenna Replacement: Schritt 6, Bild 1 von 1
    • After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
  7. iLive IKBC384S  FM/AM Antenna Replacement: Schritt 7, Bild 1 von 2 iLive IKBC384S  FM/AM Antenna Replacement: Schritt 7, Bild 2 von 2
    • Desolder the antenna at the contact point.
    • Check out this awesome guide for soldering and desoldering tips.
  8. iLive IKBC384S  FM/AM Antenna Replacement: Schritt 8, Bild 1 von 2 iLive IKBC384S  FM/AM Antenna Replacement: Schritt 8, Bild 2 von 2
    • Place iOpener on antenna for approximately 5 minutes
  9. iLive IKBC384S  FM/AM Antenna Replacement: Schritt 9, Bild 1 von 1
    • Lift up and remove all of the antenna.
    • The antenna will be glued down all the way around the radio
Abschluss
Tracy Walts
201 Reputation
2 Anleitungen geschrieben
Texas Tech, Team S46-G6, Bennett Spring 2017 Mitglied von Texas Tech, Team S46-G6, Bennett Spring 2017
TTU-BENNETT-S17S46G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 13
Insgesamt: 691
