Einleitung
This is a guide to help replace the FM/AM antenna for the iLive IKBC384S.
Was du brauchst
Make sure you remove all seven 3 mm screws before proceeding to the next step.
Be cautious when taking the top of the device off there may still be some adhesive stuck to device.
Remove all four screws(13.5 mm in length) that are securing the disk drive.
Unplug the ribbon cable connected to the motherboard that stems from the disc drive.
Also, disconnect the two power connectors from the motherboard.
After removing the top of the device, locate the screws on the motherboard. Gently unscrew all four of the 3.5mm screws on the motherboard.
