Einleitung
Use this guide to replace the LCD display.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Heavy-Duty Suction Cups (Pair)$14.95
Stick a suction cup near each of the two top corners of the glass panel.
If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a mild solvent.
Gently lift the glass panel perpendicular to the face of the LCD enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
Remove the eight 8 mm T10 Torx screws securing the display to the outer case.
Pull the vertical sync cable connector out of its socket on the LED driver board near the top left corner of your iMac.
Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
Disconnect the LCD thermal sensor cable connector from its socket on the logic board.
Carefully pull the display toward the top edge of your iMac and lift it out of the outer case, minding any cables that may get caught.
34 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
I damaged the lcd frame (with magnets) and I don't know where to find it. Can you guys help?
It's just the frame with magnets that attaches the lcd screen...
hey thanks for this.... i had to swap LCDs due to well known streak/screen fault.
after over 2 years using external display for work, i saw this blog and thought i might try.
the stakes were extremely high (my wife's iMac and no cash to get OOW apple repair, but your help got me through it. super cheers.
NB. i found this other thread most helpful re: the side strips that screw to the LCD panel and the iMac chassis.
I'd like to buy IMAC LCD Model: ME086ZP/A. Where can I buy this item?
Hi, is that possible to replace the LCD diaplay by a 4k display?
