Zum Hauptinhalt wechseln
iMac Intel 21.5" EMC 3068 Display Assembly Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. iMac Intel 21.5" EMC 3068 Display Assembly Replacement, Display Assembly Separation: Schritt 1, Bild 1 von 2 iMac Intel 21.5" EMC 3068 Display Assembly Replacement, Display Assembly Separation: Schritt 1, Bild 2 von 2
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  2. iMac Intel 21.5" EMC 3068 Display Assembly Replacement: Schritt 2, Bild 1 von 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: Schritt 2, Bild 2 von 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: Schritt 2, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
  3. iMac Intel 21.5" EMC 3068 Display Assembly Replacement: Schritt 3, Bild 1 von 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: Schritt 3, Bild 2 von 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: Schritt 3, Bild 3 von 3
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
Abschluss
Adam O'Camb
196.326 Reputation
416 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 77
