Zum Hauptinhalt wechseln
iNNEXT N64 Classic Controller Face Buttons Replacement
Was du brauchst
  1. iNNEXT N64 Classic Controller Face Buttons Replacement, Bottom Case: Schritt 1, Bild 1 von 2 iNNEXT N64 Classic Controller Face Buttons Replacement, Bottom Case: Schritt 1, Bild 2 von 2
    • Turn the controller face down.
    • Use a Phillips #00 screwdriver to remove the eight screws on the back of the controller.
  2. iNNEXT N64 Classic Controller Face Buttons Replacement: Schritt 2, Bild 1 von 1
    • Insert an opening tool into the seam between the top and bottom case.
    • Work your way around edge of the controller to release the tabs connecting the top and bottom of the controller.
    • Remove the bottom case from the controller.
  3. iNNEXT N64 Classic Controller Face Buttons Replacement, Shoulder Buttons: Schritt 3, Bild 1 von 2 iNNEXT N64 Classic Controller Face Buttons Replacement, Shoulder Buttons: Schritt 3, Bild 2 von 2
    • To remove the shoulder buttons, lift the buttons labelled with "L" and "R" upwards and out of the controller. There should not be any resistance coming out.
    • To add the new buttons, put the top notch of the shoulder buttons into the hole right above the control circuit. There should not be any resistance going in. Once done, you can put the back of the controller back on
  4. iNNEXT N64 Classic Controller Face Buttons Replacement, Face Buttons: Schritt 4, Bild 1 von 2 iNNEXT N64 Classic Controller Face Buttons Replacement, Face Buttons: Schritt 4, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 6 screws securing the joystick assembly to the top of the controller.
    • Gently lift the control panel and joystick assembly from the top cover of the controller.
  5. iNNEXT N64 Classic Controller Face Buttons Replacement: Schritt 5, Bild 1 von 1
    • Remove the silicone button gaskets.
  6. iNNEXT N64 Classic Controller Face Buttons Replacement: Schritt 6, Bild 1 von 1
    • Remove the old buttons by either pulling them out or pushing lightly from the front of the top case.
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
UMass Dartmouth, Team 3-4, Santin Fall 2024 Mitglied von UMass Dartmouth, Team 3-4, Santin Fall 2024
UMASSD-SANTIN-F24S3G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 21
