Einleitung
This guide will show users how to replace the USB port of the iNet M1001. This guide is for you if the USB port of your iNet M1001 tablet has gone bad and now needs replacing. To complete this guide some soldering is required.
Was du brauchst
Press the small suction cup on the back cover, and then pull the small suction cup to remove the back cover.
Desolder the white wire, and pull it off of the motherboard.
Check out this awesome guide for tips on soldering and desoldering.
