Zum Hauptinhalt wechseln
iPad Pro 11" LiDAR Sensor Assembly Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. iPad Pro 11" LiDAR Sensor Assembly Replacement, LiDAR sensor assembly information: Schritt 1, Bild 1 von 2 iPad Pro 11" LiDAR Sensor Assembly Replacement, LiDAR sensor assembly information: Schritt 1, Bild 2 von 2
    • The LiDAR sensor assembly is paired to the Face ID hardware. You'll need to transfer it to your replacement screen to keep Face ID functionality. The following steps show how to remove the sensor assembly and install it on your replacement screen.
    • The LiDAR sensor assembly is composed of four total sensors:
    • Two ambient light sensors
    • One proximity sensor
    • One microphone
    • You'll need to separate each sensor from the screen before removing the entire assembly.
  2. iPad Pro 11" LiDAR Sensor Assembly Replacement, Heat the top sensor assembly: Schritt 2, Bild 1 von 1
  3. iPad Pro 11" LiDAR Sensor Assembly Replacement, Separate the ambient light sensors: Schritt 3, Bild 1 von 2 iPad Pro 11" LiDAR Sensor Assembly Replacement, Separate the ambient light sensors: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    • Insert one arm of your angled tweezers between the ambient light sensor and the screen.
    • You can also use a precision knife, but be careful not to damage the ribbon cable.
    • Pry up to separate the sensor from the screen.
    • This might take significant force.
    • Repeat this procedure for the other ambient light sensor.
  4. iPad Pro 11" LiDAR Sensor Assembly Replacement, Separate the proximity sensor: Schritt 4, Bild 1 von 3 iPad Pro 11" LiDAR Sensor Assembly Replacement, Separate the proximity sensor: Schritt 4, Bild 2 von 3 iPad Pro 11" LiDAR Sensor Assembly Replacement, Separate the proximity sensor: Schritt 4, Bild 3 von 3
    • Insert one arm of your angled tweezers between the proximity sensor cable and the screen.
    • Slide the tweezers toward the screen while prying to separate the sensor from the screen.
    • This might take significant force and multiple iOpener heating cycles.
  5. iPad Pro 11" LiDAR Sensor Assembly Replacement, Peel away the tape: Schritt 5, Bild 1 von 2 iPad Pro 11" LiDAR Sensor Assembly Replacement, Peel away the tape: Schritt 5, Bild 2 von 2
    • Peel off any tape covering the microphone.
    • Set the tape aside. You'll use it during reassembly.
  6. iPad Pro 11" LiDAR Sensor Assembly Replacement, Separate the microphone: Schritt 6, Bild 1 von 3 iPad Pro 11" LiDAR Sensor Assembly Replacement, Separate the microphone: Schritt 6, Bild 2 von 3 iPad Pro 11" LiDAR Sensor Assembly Replacement, Separate the microphone: Schritt 6, Bild 3 von 3
    • Slide an opening tool under the microphone to separate its adhesive.
    • Pry up to separate the microphone from the screen.
  7. iPad Pro 11" LiDAR Sensor Assembly Replacement, Remove the LiDAR sensor assembly: Schritt 7, Bild 1 von 3 iPad Pro 11" LiDAR Sensor Assembly Replacement, Remove the LiDAR sensor assembly: Schritt 7, Bild 2 von 3 iPad Pro 11" LiDAR Sensor Assembly Replacement, Remove the LiDAR sensor assembly: Schritt 7, Bild 3 von 3
    • Slide an opening pick under the LiDAR sensor assembly cable to separate it from the screen.
  8. iPad Pro 11" LiDAR Sensor Assembly Replacement: Schritt 8, Bild 1 von 3 iPad Pro 11" LiDAR Sensor Assembly Replacement: Schritt 8, Bild 2 von 3 iPad Pro 11" LiDAR Sensor Assembly Replacement: Schritt 8, Bild 3 von 3
    • Continue sliding your opening pick under the LiDAR sensor assembly until it's completely separated from the screen.
    • Remove the LiDAR sensor assembly.
  9. iPad Pro 11" LiDAR Sensor Assembly Replacement: Schritt 9, Bild 1 von 1
    Tesa 61395 Tape
    $5.99
    • During reassembly, you'll have to perform the following:
    • Align the LiDAR sensor assembly on your replacement screen.
    • Use Tesa tape, or similar double-sided tape, to secure the cables to the screen.
    • Use E6000 adhesive, or similar adhesive, to secure the sensors to their cutouts on the screen.
    • Only apply adhesive to the edges of the sensors. Placing adhesive on the front will break them.
Abschluss
Chayton Ritter
22.449 Reputation
105 Anleitungen geschrieben
Guide Team Mitglied von Guide Team
Staff
9 Mitglieder
11.338 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 5
Insgesamt: 23
