Einleitung
Replace a malfunctioning battery to juice up an old iPod Shuffle.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
Pry the rear case away from the front case.
Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
Peel the battery up from the front case with an iPod opening tool.
Remove the logic board and battery from the iPod.
Start working from the right side of the battery ribbon cable. Heat the right solder pad while gently prying up from under the ribbon cable to free it from the board.
Repeat the previous step for the remaining solder pad.
Once the two connections have been desoldered, lift the old battery off the logic board.
4 weitere Nutzer haben diese Anleitung absolviert.
4 Kommentare
IS THIS DONE ANYWHERE IN cHENNAI-mADRAS sOUTH iNDIA PL INFORM.
Is this done anywhere in Chennai- Madras South India?
Im going to try and replace the battery with a 3rd party battery and was wondering if you knew which side was the positive and negative
