Einleitung
The iRobot Braava 375t is a floor mopping and sweeping cleaning robot. The motherboard allows for everything in the device to be connected together. This article shows you how to replace the motherboard, which may be needed if the device doesn't turn on, even after replacing the battery.
Was du brauchst
Flip device over.
Remove the cleaning cloth compartment on the bottom to access screws.
Flip the device back over and remove the shell by unplugging the wire that is holding the shell to the motherboard.
Disconnect the rest of the wires and remove all screws that are attached to the motherboard.
To remove the wires, disconnect the plastic pins in a similar fashion to the ones in the Battery Replacement guide.
Remove the zip ties holding the wires together using a sharp object or thin scissors.
Eine weitere Person hat diese Anleitung absolviert.
