Zum Hauptinhalt wechseln
Einleitung
Use this guide if your Roomba 560 is running into objects or the sensors seem to be malfunctioning. While proceeding through this replacement, it is important to keep track of the large quantity of different sized screws that you must remove.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Flip the Roomba upside down.
    • Flip the Roomba upside down.
    • Unscrew the single 5 mm screw on the yellow side sweeper using the Phillips #2 driver.
  2. Lift the yellow side sweeper, removing it from the device.
    • Lift the yellow side sweeper, removing it from the device.
  3. Using the Phillips #2 driver, remove the four 10 mm screws that hold the back panel in place.
    • Using the Phillips #2 driver, remove the four 10 mm screws that hold the back panel in place.
  4. Lift up the back panel to remove it from the device.
    • Lift up the back panel to remove it from the device.
  5. Lift up the yellow battery by pulling up the green tabs on its side. Handle the battery with care.
    • Lift up the yellow battery by pulling up the green tabs on its side.
    • Handle the battery with care.
  6. Rotate the Roomba so the bumper is in front of you.
    • Rotate the Roomba so the bumper is in front of you.
  7. Using the Phillips #1 driver, remove the ten 10 mm screws on the bumper that run along the outer edge of the Roomba.
    • Using the Phillips #1 driver, remove the ten 10 mm screws on the bumper that run along the outer edge of the Roomba.
  8. Lift the thin top cover that holds the bumper in place. Lift the thin top cover that holds the bumper in place.
    • Lift the thin top cover that holds the bumper in place.
  9. Gently lift the device upwards from the bumper to detach these two pieces.
    • Gently lift the device upwards from the bumper to detach these two pieces.
    • There are wires connecting the bumper to the device. Be careful while lifting the device off the bumper as to not damage these wires.
  10. Lift the bumper upwards for easier access. Unscrew the two 5 mm screws that connect the red and white wires to the device using the Phillips JIS #1 driver.
    • Lift the bumper upwards for easier access.
    • Unscrew the two 5 mm screws that connect the red and white wires to the device using the Phillips JIS #1 driver.
    • The sensor can be unplugged from the motherboard so the bumper isn't hanging off the Roomba.
  11. Lift the circular black panel off the lens. Lift the clear lens that is on the other side of the bumper and replace it with a new lens.
    • Lift the circular black panel off the lens.
    • Lift the clear lens that is on the other side of the bumper and replace it with a new lens.
Abschluss
5 weitere Nutzer haben diese Anleitung absolviert.
Mairead Blaes
774 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 1-22, Maness Fall 2015 Mitglied von Cal Poly, Team 1-22, Maness Fall 2015
CPSU-MANESS-F15S1G22
4 Mitglieder
14 Anleitungen geschrieben
where do I get a new lens?
Stefan Crocoll - Antwort
C’est très clair,merci.
pourtant j’aimerai savoir s’il n’y qu’un seul capteur infra rouge.
Je précise : le roomba “voit” très bien sa station de recharge mais pas les murs virtuels (ces derniers fonctionnent car je les ai testé sur un autre roomba) ?
si vous avez une solution…..:-)
hayon - Antwort
Certains murs virtuels (tels que ceux du scooba ou d'anciens models de roomba) ne sont pas compatibles de base avec le roomba 560.
Il existe toutefois deux solutions pour les rendre compatible avec le roomba :
1) Acheter un OSMO contenant la dernière version sur firmware pour votre Roomba 560 sur internet.
2) Demander un OSMO contenant la dernière version du firmware au support iRobot.
Les OSMO sont de petit appareil qui se branches sur la prise diagnostic / debugage des Roomba et qui permettent d'en mettre à jour le firmware.
Brendan -
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 3
Letzten 7 Tage: 27
Letzten 30 Tage: 102
Insgesamt: 3,485
