Zum Hauptinhalt wechseln
Was du brauchst
  1. iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: Schritt 1, Bild 1 von 2 iRobot Roomba 655 Pet Series Display  Replacement, Front Face Plate: Schritt 1, Bild 2 von 2
    • Remove the dust bin by pushing on the button for the dust bin removal
    • Pull the dust bin out
  2. iRobot Roomba 655 Pet Series Display  Replacement: Schritt 2, Bild 1 von 2 iRobot Roomba 655 Pet Series Display  Replacement: Schritt 2, Bild 2 von 2
    • Pull up on the silver handle to release the top protectant plastic
    • Remove the top plastic carefully
  3. iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: Schritt 3, Bild 1 von 2 iRobot Roomba 655 Pet Series Display  Replacement, Front Bumper: Schritt 3, Bild 2 von 2
    • Remove the ten 11mm screws that hold the front bumper to the plastic bumper protector with your Phillips #1 screwdriver.
    • Pull the plastic bumper protector up and off of the bumper.
  4. iRobot Roomba 655 Pet Series Display  Replacement: Schritt 4, Bild 1 von 3 iRobot Roomba 655 Pet Series Display  Replacement: Schritt 4, Bild 2 von 3 iRobot Roomba 655 Pet Series Display  Replacement: Schritt 4, Bild 3 von 3
    • Flip the Roomba back over, so you are viewing the top.
    • Pull up on the front bumper to remove it.
    • Be careful not to pull too hard because there is wiring attached to the bumper.
    • Remove the two 7mm screws with your Phillips #1 screwdriver, holding the wire sensors in place to the front bumper.
  5. iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: Schritt 5, Bild 1 von 3 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: Schritt 5, Bild 2 von 3 iRobot Roomba 655 Pet Series Display  Replacement, Internal Faceplate: Schritt 5, Bild 3 von 3
    • The outside six - 10mm screws and the inside set of four - 10mm screws are the same here, use your Phillips head #2 to remove them
    • Use your Phillips head #0 to remove the one - 7mm bottom center screw
    • Use your Phillips head #2 to remove the two - 8mm screws by the handle
    • Push down the two release points to pull the plastic piece up
    • Pull the plastic piece up
  6. iRobot Roomba 655 Pet Series Display  Replacement, Display: Schritt 6, Bild 1 von 3 iRobot Roomba 655 Pet Series Display  Replacement, Display: Schritt 6, Bild 2 von 3 iRobot Roomba 655 Pet Series Display  Replacement, Display: Schritt 6, Bild 3 von 3
    • Pull the silver tab, and clear tinted display off
    • Remove the 4 - 9mm screws holding the display with your Phillips head #0
  7. iRobot Roomba 655 Pet Series Display  Replacement: Schritt 7, Bild 1 von 3 iRobot Roomba 655 Pet Series Display  Replacement: Schritt 7, Bild 2 von 3 iRobot Roomba 655 Pet Series Display  Replacement: Schritt 7, Bild 3 von 3
    • Remove the display
    • Remove the plastic protectant film from the motherboard
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Rhett
1.310 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 21-20, Maness Winter 2015 Mitglied von Cal Poly, Team 21-20, Maness Winter 2015
CPSU-MANESS-W15S21G20
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 5
Insgesamt: 732
