Einleitung
This guide will teach you how to access, remove, and replace your iRobot Roomba 692 filter and dustbin. If you are replacing the filter, ensure that you have the right filter for the Roomba 692 prior to removal.
Remember to review the iRobot Roomba 692 Troubleshooting Page before attempting any maintenance or repairs on your vacuum.
Was du brauchst
Rotate the Roomba so that the "R" on top is facing toward you
Press the button at the bottom of the Roomba
Press down on the button and lightly pull until the dustbin is fully removed from the Roomba.
Pull on the yellow tab to open the filter latch.
The dustbin can now be emptied or cleaned.
