Was du brauchst
Use a Phillips #2 screwdriver to remove the 7.7 mm screw securing the side brush-head.
Lift off the yellow brush head.
Place the Roomba with its bottom facing toward you.
Use a Phillips #2 screwdriver to remove the four 11 mm screws.
Remove the battery plate.
Remove the battery by pulling directly up on the grey pull tabs.
Turn the Roomba face up.
Press the release button on the top side of the Roomba and pull the dustbin straight out.
Use a Phillips #2 screwdriver to remove the ten 9.3 mm screws.
Remove the bumper retainer ring.
Use a Phillips #2 screwdriver to remove the two 7.5 mm IR Sensor screws.
Remove the IR Sensor assembly.
Use the iFixit opening tool to remove the retaining band.
Use the iFixit opening tool to remove the faceplate.
Use a Phillips #1 screwdriver to remove the two 9.5 mm handle screws.
Use a Phillips #1 screwdriver to remove the fourteen 9.5 mm top plate screws.
Remove the top plastic plate.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
