Zum Hauptinhalt wechseln
iRulu AX760 Motherboard Replacement
Was du brauchst
  1. iRulu AX760 Motherboard Replacement, Battery: Schritt 1, Bild 1 von 3 iRulu AX760 Motherboard Replacement, Battery: Schritt 1, Bild 2 von 3 iRulu AX760 Motherboard Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use a plastic opening tool or metal spudger to free the rear cover.
    • Insert your spudger into the side of your tablet.
    • Crack open each edge and remove the cover.
  2. iRulu AX760 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Open your tablet.
  3. iRulu AX760 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Take your plastic flat head tool and insert it under the battery.
    • Lift the battery up.
    • Make sure to remove any tape from the battery.
  4. iRulu AX760 Motherboard Replacement: Schritt 4, Bild 1 von 2 iRulu AX760 Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use a soldering iron to remove the solder that connects the black and red wires of the battery to the motherboard.
    • Keep the wires of the battery taught.
    • The iron should only be pressed to the solder for 2-3 seconds max.
    • Be very carful, the soldering iron will be very hot!
    • Visit this link for information about soldering. Wie man Lötverbindungen herstellt und entlötet
  5. iRulu AX760 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove your old battery and replace it with the new battery.
  6. iRulu AX760 Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 2 iRulu AX760 Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Plastic Cards
    $2.99
    Kaufen
    • There are two thin adhesive strips under the battery that run vertically along the left and right side.
    • Carefully wedge a plastic card or spudger under the battery and along both adhesive strips. Gently work the card or spudger up and down to free the battery.
    • Do not use metal tools, and do not bend or puncture the battery.
  7. iRulu AX760 Motherboard Replacement: Schritt 7, Bild 1 von 3 iRulu AX760 Motherboard Replacement: Schritt 7, Bild 2 von 3 iRulu AX760 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • WARNING: SOLDERING IRONS BECOME EXTREMELY HOT. DO NOT TOUCH
    • For information on soldering and desoldering, check this link.
    • You must desolder several sets of contacts before attempting to remove the motherboard.
    • You must desolder the BAT (battery), LED, SPK (speaker), and ANT (antenna) contacts.
  8. iRulu AX760 Motherboard Replacement: Schritt 8, Bild 1 von 2 iRulu AX760 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the motherboard from the screen with the JIS #000 Screwdriver, a Phillips-head type screwdriver
  9. iRulu AX760 Motherboard Replacement: Schritt 9, Bild 1 von 2 iRulu AX760 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Use a plastic spudger to push the tab, releasing the motherboard from the screen. You can now remove the old motherboard.
    • You will not need a metal spudger in order to re-place the motherboard
Abschluss
Adam Schubach
123 Reputation
1 Anleitung geschrieben
IUPUI, Team S6-G4, Baechle Spring 2018 Mitglied von IUPUI, Team S6-G4, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G4
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 324
