Zum Hauptinhalt wechseln
ionvac SmartClean V2 Side Brush Replacement
Was du brauchst
  1. ionvac SmartClean V2 Side Brush Replacement, Side Brush: Schritt 1, Bild 1 von 2 ionvac SmartClean V2 Side Brush Replacement, Side Brush: Schritt 1, Bild 2 von 2
    • Caution: Before beginning, turn off the ionvac and place it on a level surface.
    • Flip your ionvac upside down so the wheels are pointed upwards and the side brushes are furthest from you.
    • Grasp the half-circle holding the brush into the bottom of your ionvac.
  2. ionvac SmartClean V2 Side Brush Replacement: Schritt 2, Bild 1 von 1
    • Gently pull on the brush head until it is released from the frame.
    • If the side brush is stuck, you can use a pry tool to pry it out.
    • Check out our Troubleshooting Page for cleaning instructions.
Abschluss
Ruth Mekonnen
737 Reputation
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 23
Insgesamt: 132
