Zum Hauptinhalt wechseln
2.3L 4cyl or 3.0L V6, 6th Generation
20 Fragen Alle anzeigen
I need the Specific 5-Digit Code To enable my car stereo
Friends,Please help with the specific 5 digit code required to activate my car radio after its disconnected from power. I do not have the car owner's manual because I am not first user of the car.Thanks
Regards,
Ikem
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 26
48 Kommentare
I need my code for the radio U2722l1353 can u help me plz
von
Hello, I need my code for my Honda Pilot radio. Chassis number 2HKYF18463H501898 , Engine number J35A42502249. Thank you.
von
Hi I Need my code for my honda CRV 2006 radio. Chassis number JHLRD78456C408404 and Radio number 10001792
von
hi need code for my jeep cherokee sport radio vin nr 1J4GM48713W524250
von
Hi ...coild u halo me to find out my radio code for the honda accord vtec 2001 please
Vn br:SHHCG96401U200505
S/n:10002482
von
43 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
caiusonline. there are a couple of things you can try:
1. Look in glove box for small sticker with numbers, should be 5 digits with numbers no greater then 6.
2. Pull out the ashtray and see if the sticker is on the back of there.(older models that have them)
3. Pull radio from dash and write down radio serial number and call local dealer with that number and they will be able to get the code for you. They will ask verifying questions.
One more thing you can do is that Honda has a radio reset website radio reset website, this is an automated service that can provide your Honda stereo code. Just write down the serial number of your radio and the VIN number of your vehicle then contact Honda. The VIN number is located on the driver side of your Accord vehicle just behind the windshield. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 12
4 Kommentare:
I don't have the number nothing in glove box
von
My car's radio unit had the same problem and i solved it here http://unlockradiocodes.com/honda
von
Bought 1999 Honda accord needed new battery. Put new battery in it radio don't work. I heard I need a radio code. No owners manually. How can I get the code?
von
honda radio codes free here -> http://radiocode.io/
von
Hey, guys! If you are in need of a radio code, I suggest you check out http://unlockradiocodes.com. My car battery died on me a couple of days ago and my radio was rendered useless as a result. They were kind enough to give me my code and the guides in their website helped me a great deal as I’m not much of a car person. My radio is working again now so I can definitely vouch for their service.
Bewertung 4
5 Kommentare:
Worked for mine
von
On my accord the code that site gave me ended up unlocking it. Works, thanks
von
Just wanted to say that this is a working solution.
von
radiocodevault.com was the site that ended up working out for my good ol civic ;) Music is on rock once more, lol
von
thank you, I was emailed my code quickly as well.
von
This happened with mine too, battery disconnected than it locked up and said CODE.
Here is how I solved it:
I went to this site https://radiocodevault.com/honda/ and they got me my code in around 30 minutes.
Hope it helps some other people out :)
Bewertung 3
4 Kommentare:
Thanks a lot! It worked!
von
Unlocked my CRV just fine
von
yes, it worked!!!
von
working for me as well
von
That site someone mentioned above, actually works! :D I just used it and got a working radio code. Music again!
https://radiocodevault.com/honda/ is the link.
Bewertung 1
Nesesito que me ayuden a deslaquiar mi radio honda prelude1998. Serial no. 96D311208. Ref.No CQ-JH2610A
Bewertung 0
1 Kommentar:
Hey there, sorry I don't speak spanish, but for anyone else, just enter the serial number here https://radiocodevault.com/honda/ and they will give you the unlock code.
von
Why don't any of those fake answers mention that radiounlockcodes.whatever want $19 to ‘kindly give' you your code. Pfft…
Bewertung 0
1 Kommentar:
… and radiocodevault… $18.95 … i'd hardly call that ‘kindly giving'. A fellow a few squares above left a link which is actually free.. Derick i think his name was… its
von
Antwort hinzufügen
caiusonline wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 37
Insgesamt: 153,830
