Zum Hauptinhalt wechseln
Model A1236 / 4 oder 8 GB Speicherkapazität
134 Fragen Alle anzeigen
Two beeps and black screen.
I have the same problem as Angela but my screen is always black, when I try to reset it (by holding the menu and select button for 6sec) it just powers off and back on but still gives the black screen. Then it beebs 2 times, just like Angela's I suppose. I just tried to reset it via iTunes but it still shows a black screen. I can hear the clicks when I use the click wheel. What do I do ?
Greetz James
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
My iPod will not turn on I put it on the changer an it beeps 2 times dose that mean its changing
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
jamesschelfaut, there are a few possibilities, but they all require you to disassemble your iPod. It could be loose ribbon cables, corroded connectors, a bad LCD and/or bad backlight circuit. I would check it in that order. Here are the guides to work on it. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
jamesschelfaut wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 30
Insgesamt: 8,888
