These are a few basic tips I stick to:
1) don't let it get too cold, if your battery gets too cold it will lose charge, this is why your phone will magically die even though you just charged it when you're outside in the winter. If your battery ever ends up getting rather cold, try to warm it (just taking a phone battery in your hand and rubbing it works fine- I guess this doesn't apply to iPods/iPhones though because of no removable battery)
2) this is pretty much a no-brainer, but don't block your fans
3) Some people say don't overcharge it, this mainly is an issue with older 90s era electronics, but doesn't factor in now as as I'm sure you more than know, electronics are so much smarter today
4) Clean it/make sure it doesn't get dirty, this is actually really good when applied to cars, cleaning corrosion on the terminals of a car battery can add up to a year or more to the battery's life. Periodically check all batteries, especially when hidden inside like with iPods, for cleaning.
5) Only use good chargers, don't try messing with strange 3rd party who knows what chargers, I do my best to avoid them, some people like saving money, others like not taking risks with batteries (and strong electric currents in general!).
6) Common sense: Should I see what noise this battery makes when dropped from different heights?
Number six is key.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
3 Kommentare
Hey, I just noticed this article from the NY Times about this, and it's even got a quote from you in it!
von rab777hp
Ha! I asked this question as part of my research for that article. I think it turned out pretty well!
von Kyle Wiens
Well too bad it didn't turn out much but that's a good tip you have there. I put my phone into airplane mode when I need it on but want to conserve battery and don't expect calls.
von rab777hp
