Zum Hauptinhalt wechseln
Apples Laptop-Serie für Nutzer:innen mit höheren Ansprüchen im beruflichen oder privaten Gebrauch. Bislang gibt es Modelle in den Größen 13, 14, 15, 16 und 17 Zoll. Die wichtigsten Entwicklungen gab es beim Prä-Unibody (Original), Unibody, Retina Display, Touchbar und SOC (system-on-a-chip) Design.
20001 Fragen Alle anzeigen
would you be able to fix water damage on a MacBook Pro?
I got not a lot, but enough to do damage, amount of orange juice on my laptop. Going to apple it was said to be priced 1200 dollars to be rebuilt, is there any way you could help me at a lower rate?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
iFixit is not a repair service, it is a resource to help you repair yourself. By asking here and consulting guides and being able to purchase parts and tools you can do by yourself for less what would have been a costly repair job.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Good chance it can be fixed for much less. Was it on when the juice got spilled? What happened to the computer? It can most likely be cleaned using distilled water. We need to know exactly which MacBook Pro you have to direct you to a teardown. Did Apple open it up? What did they do?
War diese Antwort hilfreich?
Bewertung 3
3 Kommentare:
This should be a comment, not an answer.
von
Cleaning with distilled water is not a comment.
von
Your answer was hidden in a plethora of questions, now that I see you indeed have an answer in your answer, I will reverse the downvote. I hope you will also revert the spam downvotes you just did to my account. Thank you
von
Use NON Conductive Component spray which you could find at Radio Shack and generously spray down everything internal including the motherboard and all surrounding components. Allow the MBP to rest in a well ventilated area for 1 hour..it did the trick for my 2010 Macbook Pro i7 which I made add is working perfect.
Bewertung 0
Antwort hinzufügen
allie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 2,348
