Zum Hauptinhalt wechseln
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
50 Fragen Alle anzeigen
Can I use a 800 mhz DVI logic board
I have a PowerBook G4 667 mhz DVI 15 inch with a bad logic board. Can I replace it with a 800 mhz DVI 15 inch logic board? are they interchangeable? Also, what about switching display assemblies from one to the other?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes, you can put a 800 MHz DVI board in a 667 MHz machine, but it is recommended to also install a secondary fan as well (the 667 MHz machines do not have the secondary fan). As for the displays, DVI displays are also interchangeable. You cannot, however use earlier Titanium model displays (Mercury or Onyx machines).
Good luck!
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
I knew you would know. Can he also go to the 1000 MHz board? +vote
von
yes! but he would need a different secondary fan.
von
Where does a Powerbook G4 Titanium DVI 867 secondary fan plug in?
Please reply to RHBernard@gmail.com of 203-984-2070
von
You may be in luck. There are four logic boards listed for the G4 Titanium. A 667, 800, 867 and a 1000. Ben Eiseman is the parts man around here. He should be able to tell you in the morning which ones will work. Here's the boards: http://www.ifixit.com/Mac-Parts/PowerBoo...
Bewertung 0
Antwort hinzufügen
robert owen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 834
