Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2396 Fragen Alle anzeigen
Frage geschlossen
battery discharge very fast iPhone 4
After drop my iphone 4 into water it works ok but battery discharging even on stand by very fast in 1 day. I have new battery but still the same. What else can be replaced to fix this problem?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
sergiy, it is easily possible that you are having corrosion failure. I would suggest that you take the time and clean your iPhone. Use these guidesto work on your phone. This guide will show you how to clean it. It was written for a 3G but all the points are still valid for your phone. Once you have it properly cleaned, take a look around the power management IC as well as the dock connector. Look for charred, or missing components.
War diese Antwort hilfreich?
Bewertung 1
Hi,
At least you have changed the battery, I would also recommend restoring your iPhone in iTunes. That did work for me.
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,312
