Zum Hauptinhalt wechseln
The Garmin eTrex Vista-H has a 2.0" x 4.4" x 1.2" body, and a black and white screen with 160 x 288 pixels display resolution screen. It weighs 5.3 oz or 150 g, and requires 2 AA batteries which last up to 18 hours. The device is water proof but does not float.
I applied 12 V directly to the GPS Garmin etrex Vista H
i applied 12 V DC supply directly to the GPS GarmineTrex Vista H. Now it wont turn on. how do i fix it?
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
kiani, disassemble you Garmin ny following this guide. Check the motherboard for any charred, burned or missing components. Right now, my guess would be that there is a SMD fuse that may be burned. Use an ohmmeter to check for continuity.
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I borrowed it from my boss so i dont want to add fuel to the fire by opening it and risking anything else :) do u reckon that the problem maybe more than burning of fuse?
von
Antwort hinzufügen
kiani wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 1,048
