Zum Hauptinhalt wechseln
Repair guides and support for Kenmore washing machines.
1861 Fragen Alle anzeigen
Can I replace parts on a Kenmore HE4T washer?
I would like to know if someone can replace the motor control unit and motor to a Kenmore HE4T washing machine. I would like to do it myself if possible. I would buy the parts myself.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
rm2sm, it is most certainly possible for you to replace it. The motor controller should be on the left side behind the lower access panel and the motor. Once you remove the panel you should see it. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Your machine is actually a Whirlpool. Kenmore (Sears/KMart) doesn't actually make ANYthing. So you may want to start by finding which model of Whirlpool washer you have and get parts from them.
Bewertung 1
1 Kommentar:
Your Kenmore HE4T is actually a Whirlpool Duet.
von
Antwort hinzufügen
rm2sm wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 1,027
