cant connect the the lcd cable
the cable which gets connected to the socket at the top of the logic board is very hard to connect agin. It is not going in. What to do??????
Ist dies eine gute Frage?
The ribbon cable can get easily tucked in-between the the glass and mid frame. Make sure it goes all the way through so there is enough length to reach the connection point.
War diese Antwort hilfreich?
I think Zachary is confused with an iphone 4. screen swap where that happens.
yes it's tricky, You need to straighten the flex a little and then align it perfectly with the connector. Then insert the topmost edge of the connector at a downward angle towards the metal shield lip and then thumb it down. takes practice. Don't over press it as you'll damage the connector and then the ipod will be toast.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 985
