Zum Hauptinhalt wechseln
The Roomba Red 4100 is a vacuum cleaner robot produced by iRobot that can clean a room all on its own.
12 Fragen Alle anzeigen
Keeps Circling In Same Area
Keeps circling same area over and over and then stops. Battery is still charged. How do I correct this problem? Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Diane, this can be caused by dirty or defective bumper sensor as well as dirty cliff sensors. Clean the Roomba with compressed air and "slap" the front bumper. Apparently, the front bumper mechanism can get stuck with any contact with a wall etc. which will make the Roomba back up. Use these guides to work on your Roomba. Check on here for more information as well. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Did the trick thank you!
von
Antwort hinzufügen
Diane wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 20
Letzte 30 Tage: 25
Insgesamt: 10,277
