Zum Hauptinhalt wechseln
The third generation of the Toyota Camry in all markets outside Japan. 1991-1996 was also called the XV10 series of Camry vehicles.
How to remove dash panel to replace Radio
Trying 2replace the cd deck. Dash seems simple to remove but the trim panel wraps round the ignition hole. How do I remove the panel without damaging it?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Dee brown, check on here for a broken down service manual. the instrument cluster removal is described in the "BO" file. Hope this helps, good luck
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
That was exactly what I needed. Truly, truly, appreciate it. Got a few other things 2do on this car as well & this has all the answers. Thank u, oldturkey03. Ur a scholar & a gentleman
von
you are welcome :-)
von
hey I have the same problem. what do you do to unlock the clips
von
Antwort hinzufügen
Dee Brown wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 6,882
