I am unable to here voice in palm pre plus
When i answer any call unable to here voice when i switch it to loudspeaker i am able to here, that is my phone problem.
can any one solve the my problem ASAP.
Ist dies eine gute Frage?
surya, sounds like a blown earpiece speaker. Check this video for instructions. For further repair guides check on here. Hope this helps, good luck
War diese Antwort hilfreich?
I've run into this on my Pre+ and Pre 2 and often it's the sensor in the headphone jack not working correctly. The phone thinks a headset is still plugged in even when one isn't. This usually happens to me after I've had headphones or a cable plugged into the phone.
Short of taking the phone apart to clean or repair the piece in the headphone jack, I usually plug and unplug something into the jack until it manages to fix itself. I'll try playing music using the music player: if it's playing but you don't hear anything out of the speaker, the phone still thinks a headset is plugged in. Once the headphone sensor correctly identifies nothing plugged in, you will hear the music on the phone speaker.
Hope this helps!
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 630
