TV doesn´t turn on
Hello. I have a SAMSUNG UE 40 D8000 that doesn´t turn on. I have changed the capacitors but the TV still doesn´t turn on. Could somebody give any advise?
Ist dies eine gute Frage?
si les condensateurs de l alimentations changés suivant le modele il faut reintialiser la memoire court circuiter la memoire pin 5 et 6 demarer le tv et supprimer le court circuit et attendre quelqus secondes le tv redemare ensuite
War diese Antwort hilfreich?
measure tuner pins voltages.........when you were replacing capacitors maybe a small part of lead made a short circuit.....clean around your working on chassis with a non-usable tooth brush . If you need a tech service I can recommend you these guys www.tvrepairjacksonvillefl.com but they work in Jacksonville FL, you should search a similar service near your zone.
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 623
