How do you bypass the locked passcode?
I bought a salvaged ipod and it's locked. how do i bypass the passcode and reformat it?
Ist dies eine gute Frage?
Cody, here is my answer from a similar question"you can restore the device on the the same computer that you normally use to sync your ipod. Put the device into DFU mode, then open iTunes. Select your iPod in the sidebar, and click restore. This will restore the device to factory setting but it will DELETE ALL YOUR DATA if you have not backed it up, it will be lost. You put your iPod in DFU by
Turn off iPod
Hold power button for 3 sec
Hold power and home button for 10 sec
Continue to hold home button until iTunes pops up a message telling you that it has detected an iPhone in recovery mode. The screen should remain black
The only other way that I know of that you might try first is to erase the password but I am not sure if this would work when you are already disabled. This will not erase any data on your device. I guess you can always try and hope you have a windows computer :-) anyhow you plug in your iPod. Open My Computer (or Computer for Vista). Click on Folder options and enable to view hidden files. Next go to iPod_control and click on the folder named Device. If your iPod is locked, there will be a file _locked . Rename the file to _unlocked. Remove your iPod and it will be cleared" you can also check on here My iPod is frozen says I pod disabled?... Hope this helps, good Luck."
War diese Antwort hilfreich?
Worked for me! Thanks!
If you encrypt an iPod Touch backup on iTunes and then forget your password, you will not be able to restore from backup and your data will be unrecoverable. If you forget the password, you can continue to back up and use the device, however you will not be able to restore the encrypted backup to any device without the password. You do not need to enter the password for your backup each time you back up or sync.
If you cannot remember the password and want to start again, you can use a SmartKey iTunes Backup Password Recovery to unlock iTunes backup password at first.
For iPod touch load your password your iPod will glitch that means that you should be able to get into the iPod home screen
I have iPod A1509 and I restored using iTunes but still the password is still there so what can I do
I have a 5th gen iPod touch I bought from a pawn shop but it's disabled, it's asking for the persons Apple ID and password, does anyone know how to restore it and erase the Apple ID
Yes. This is something I have done many times before.
1. Download Itunes onto your computer.
2. Power off the device.
3. Hold the home button and plug the ipod into the computer with itunes.
4. On the computer, click restore, then restore and update.
5. Let this process run and when it finishes, you will have a fully working Ipod.
Hope this method works for you.
Best of luck
-- Ir0nTr4c3
Damian Martinez, were you able to fix your problem? I tried this method and it didn't work for me. I have the same situation. Thanks in advance. Mar
How do I track my iPod down and I don't have my icloud accounts info I have the email but not the password how do I do that
Just refer to https://www.isunshare.com/iphone-ipad/re...
don't have internet, don't no longer have org computer, living in the woods in a trailer, phone has the internet, forgot my ipod, 4 combination number lock. any help
Letzte 24 Stunden: 13
Letzte 7 Tage: 79
Letzte 30 Tage: 315
Insgesamt: 134,423
5 Kommentare
Cody, it does help if you could identify your devices you are asking questions about. There are 5 versions of the iPod touch....;-)
von oldturkey03
i tried to press0000999111 and it worked rry it but might not work
von layl
I have an iPod touch 6th generation that has an activation lock on it. How do I bypass that or jailbreak the iPod? I don't have the iTunes account or the password for it
von Tina Woodby
I have an iPod and I want all my photos and videos off it but I don't know my password
von May Denny
I have an iTouch 5th generation that I purchased used and need to bypass the password. It didn't have it when I purchased it but when I restarted the iTouch now its asking for the original password. Help is appreciated.
von Mar Paz
