Zum Hauptinhalt wechseln
CDMA Version des iPhones der vierten Generation. Die Reparatur ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. Modell A1349 mit 16 oder 32 GB, CDMA Kompabilität.
295 Fragen Alle anzeigen
Frage geschlossen
unlock keypad 7,8,9 not working
just replaced the broken glass on this phone and the unlock screen does not work. when I press on the 7,8, or 9 the number above 5,6, or 7 or the buttons below are activate. No matter how precisely I push these numbers they will not work and therefore I am unable to unlock/use my phone. I have tried re-booting it several times
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi did you fix the broken screen yourself or you went to a repair shop?, if you fix it yourself then i would suggest you disassemble your phone, disconnect and reconnect your lcd and touch panel cable, it could be improper connecting of lcd able ribbon that cause this issue, if you went to a repair shop then i would suggest that you return back to the shop and ask for assistance, hope that helps cheers, and alos it could be a case of a faulty lcd and touch panel due to manufacturing defect, so try the above first before trying another lcd and touch panel, cheers!
War diese Antwort hilfreich?
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 2,127
