Zum Hauptinhalt wechseln
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Fragen Alle anzeigen
How can I fix this?
My Ipod touch 4th gen. screen was broken and I repaired it. Now when I try to turn it on, a white screen shows up.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
make sure all the connectors are connected and try doing a iTunes restore
War diese Antwort hilfreich?
Bewertung 0
do you sure the konectore scren put correctly? make sure the screen type corect too
Bewertung 0
If the LCD connectors are properly connected then try resetting your device by pressing and holding home and power button until the screen goes black and turns on again. If this thing doesn't help then you may need to go for LCD replacement.
Bewertung 0
1 Kommentar:
Did you bother to look at the date the question was asked? I doubt bakerkylee still has a problem here.
von
Antwort hinzufügen
bakerkylee wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 199
